- Joined
- 5 Oct 2020
- Messages
- 143
- Reaction score
- 3
- Country
Hi All, I've put a new sink and taps in and plumbed it all in tonight.
However, I put PTFE tape with a bit of joint compound over both the hot and cold feed joints, and when doing the hot one I think I may have overdone it with the PTFE tape....
I did it up by hand approx 4 turns and then could only get about another half turn on it with the wrench. Its on a valve at the bottom of a flexi pipe to the taps, and there are still a good few threads showing at the top that's it's not covering.
I was expecting it to leak straight away when put the water on and was going to undo it and redo, but everything is bone dry not even the slightest bit of sweating.
Now I don't know if i should undo it and redo or just leave it?
I'm worried about it possibly falling off under pressure? (although the full pressure is on already)
If it's not leaking then what's the chance of it falling off? Quite slim? If I got 4 turns out by hand then another half turn with the grips?
