joint sealer concrete-to-pvc and pvc-to-pvc driveway channel drain
29 Jul 2009
London
Looking for recommendations on product to use to get a watertight seal for joints in my driveway channel drain.
I will need to seal a joint between concrete and the floor of the pvc drain.
I will also need to seal joints between sections of the pvc drain (around 1mm where they butt up against each other).
Ideally the same product would work for both applications but not the end of the world if that's not the case.
Many thanks in advance!
