FredFlintstone said:Out of interest, why are you using tapered edge boards?
joe-90 said:FredFlintstone said:Out of interest, why are you using tapered edge boards?
Because they are the best boards to use. Scrim and adhesive are in a hollow so skimming is a doddle.
joe-90 said:OK - the manufacturers are wrong and you are right.![]()
joe-90 said:Fred. The difference is that you can skim in one coat instead of two.
joe-90 said:I can get a perfect finish on plasterboard in one coat. It's a perfectly flat finish to start with - so what's the problem? In a two coat system the first coat is a coat to even up uneven surfaces - but that's already been done on plasterboard.
