I am boarding out my bathroom with a combination of green (mr) and standard 12.5mm board, both are tapered edge, my question is when I joint tape the joins do I need to use some finish plaster in with the joint tape or leave it just with tape as I will be tiling straight to the board afterwards?
The boards are dot and dabbed with additional mechanical fixings should I tape over the screw heads as well?
Thanks in advance
Thanks in advance
