joist bolt length
10 Nov 2015
hello
i am planning on fixing face joist hangers to support 2inch by 6inch joists on a stone wall in my cellar.
how long should the m12 bolts be?
thanks
Stupid answer :- It depends on the strength of the stones used in the wall. I would have thought that 4" will do in most stone, perhaps 6" in sandstone which can be very soft. Four of them per hanger?
Frank
Hi Frank thanks.
the simpson tie face fixing joist hanger has 4 holes for m12 bolts.
i decided to use anchor sleeve bolt type, so i dont have to use rawl plug and chemical mortar.
http://www.strongtie.co.uk/products/detail/face-fix-hangers/39
the stone wall is very hard to drill into. i have a black n decker 3000rpm drill.
i use the hammer setting, have bought a special masonery dewalt drill set [that amazon reviews said was good on hard stone].
but the dewalt and my other masonry drill bits, after 3minutes of timed drilling. have only penetrated 2cm of the stone.
is this length of time/ penetration rate normal?
do i need to buy a more powerful drill?
You need an SDS drill. Fast speeds will burn the bit out.
Fixings are generally 2.5 x the width of the timber being fixed.
I agree you can get a a cheapo SDS drill from catalogue suppliers. My one worked fantasticaly( many holes over 600mm in lime stone!!), drills 10mm in lime stone at a rate of 6" per minute. I had to mend it because the automatic overload clutch let go. I tightened up the nut gave it to my son and bought its big brother (~£70). Its a brute to handle but it drills at twice the rate.
Frank
Dewalt SDS for £60. Use code DEW20 (y)
www.toolstop.co.uk/dewalt-d25133k-sds-hammer-2kg-3-mode-26mm-240v-p71687?
