hi all,
Just installing the main double joists for my loft conversion and the design specs them to sit 150 higher than the floor because two of them are supported by a steel ( See attached layout )
Anyway I've obviously got to sling the cross joists between the rafters but need to get them as low at possible.
The joist hangers I've bought look too short now ( live n learn ) so can you recommended the correct hanger please ? Or maybe a solution ?
I understand that I can only notch the joist ends to drop it down by 1inch ?
Is that correct ?
Is that correct ?
