Building a garden office and using piles for the foundations. On top of the piles I'm going to build my base frame however there are two things I'm unsure about. The first is the size of timbers I should use and secondly is the amount of piles/span. I'm considering either 4 or 5 by 2" timbers and wondered if piles every 100cm would be ok? I'm going to have the timbers spaced every 60cm so a celotex sheet cut in half will fit and will run t&g chipboard across the joists but would appreciate someone's advice as I really don't want the floor to flex.
Thanks guys
Thanks guys
