Hello!
I'm hoping for a bit of advice re. a loft conversion. I'm just at the stage of figuring out how to do it, what to get others to do for me, how much, etc!
Whilst I've got a good idea of most other areas, an outstanding issue is the new floor. Whilst I'll probably get a carpenter to actually put them in for me, I'd quite like to get it straight in my head what I need them to do. I had initially assumed I would get new joists laid from the front wall through to the centre wall of the house and then the same again to the back wall.
Having had a dig round the eaves I've realised this may be rather tricky. Above the front and rear walls there is only a few inches clearance between the top of the wall and the slates. I'd initially thought perhaps cutting the ends of the new joists at a slight angle or removing a corner would allow them to fit in. However, it looks like this would remove so much 'meat' from the joists it would seriously weaken them?
So what to do to get round this? I assume this is a common problem? My inexperienced head thinks I'd either have to lower the ceilings below, eek! Or install a rather large trimmer (if that's the right word) between the two side walls of the house (about 15ft) and hang the new joists off that?
Thanks in advance for any thoughts.
Dave
Dave
