I have a problem with a compressor fitting (I was unsure which catagory to put this in). I have a hose 8mm ID, attaching to the appropraite size hose tail. It is a good fit onto the hose tail but when I tighten up the connection with a jubilee clip I get an air leak.
Tightening the jubilee clip further cause the threads on the clip to strip before the leak is stopped.
Would I be better off with those 'O' clips where you crimp the lugs to form a tight seal??
The hose clips I used are made by Jubilee and are 9-12mm. The hose is 10mm ID from Machine mart (braided clear hose). Air pressure is set about 6 Bar.
Thanks in advance.
Thanks in advance.
