Hi again
I probably missing something but ...
Am trying to connect a Bosch hose to an extension via the white coupling you can see in the below pic
The extension hose on the left - fits on fine - but the Bosch hose doesn't seem to far enough onto the connector (maybe only half way?) - and drips
So - what am I doing wrong ? The bosch hose seems to be a much harder plastic than the rubbery end of the extension hose
Should I even use a connector ?
Or does the extension just go over the Bosch hose ? ( I am using jubilee clips)
Or do I just need to tighten the clip more (it was pretty tight already - and I don't want to crush the Bosch hose)
Sorry for the silly question and as usual many thanks in advance
