just fitted TRV struggling to get rads on afterwards
17 Sep 2003
hi.
was very pleased to get a replacement rad fitted & TRV but now after bleeding all rads only the upstairs bedroom rads are on..bathroom is luck warm & no downstairs rads are on.../cant work it out,,,gut feeling is an air lock somewhere
any ideas
normal system with a tank..not combi
many thanks
hi....eurostar oil boiler..tank in air cupboard..grundfos pump
all rads are bled./.all rads have water in...how do i tell if the system is full>?
i found a bleed valve in airing cupboard....bled that...wonder if theres more somewhere..
when i turn heating on pump sound louder than normal...thanks for help
theres a big disc on the front of the pump (about 1 inch across) is that the bleed valve?
have a look at the FAQs at top of page, it will lead you.
there is a big silver slotted disc on the front of the pump.
turn off central heating, remove slotted disc, allow water to dribble from pump, also spin the shaft with a screwdriver, to check the pump rotates freely,replace slotted disc and turn on central heating
If it has a slot it's a screw - undo until water comes out.
See what speed it's set to . It can make matters better - or worse, to set higher.
Then close any rads which get warm. That'll force air into the other rads.
If any refuse, you have a sludge problem, like many many others.
cheers guys....all that bleeding & a nights sleep kicked the whole thing into life!
