Thats only a diagnostic fee for fault finding.
Kent is SE of London and must be in MK territory !
The obvious simple solution is to run a correctly sized pipe up the outside of the building.
The OP has not explained why the 15 mm cannot be upgraded to 22 mm.
I thought we were still meant to turn off anything classed as At Risk or has it changed since I did my ACS last August ?
Tony
AT RISK is defined as
having the potential to be dangerous, but does not mean that it is, therefore, the operative had no right to cap the supply to the appliance!
AT RISK you are advised to TURN the appliance of i.e the rotary switch on the boiler to zero and advise that should they continue to use it, then they do so at there own risk.
All in all, insufficient working pressure at the inlet to a room sealed fan asissted boiler will only create a situation where the heat output of the boiler is reduced and due to the way modern air/gas ratio valves operate, if anything there would be to much air in relation to gas which, would only reduce the efficiency of the appliance.
Hardly a reason to disconnect the supply, another instance where poorley trained/inexperienced operatives go to far.
BG are by far the worst!
Note: with the use of a flue gas analyser and all readings being well, it could be classed NCS.
