    Dismiss Notice
Karcher 2.59M power wash motor runs but no pressure
Discussion in 'Tools and Materials' started by Stevie5tapes, 1 Jul 2012.
  1. Stevie5tapes
    Stevie5tapes
    13 Jan 2008
    49
    Thanks Received:
    Bradford
    Country:
    Hi all,
    I was using my Karcher power wash today when all of a sudden the pressure just dropped to a trickle. The mains water and electric were fine. When I turn the switch on the motor just runs continuously. When I squeeze the trigger there is just a trickle of water. Has anybody come accross this before? Anyone know of the fix?
    Many thanks for looking!!
  2. Burnerman
    Burnerman
    7 Feb 2008
    23,138
    Thanks Received:
    4,499
    Northumberland
    Country:
    It'll be a crack on the plastic pump head, more than likely....esecially if the machine was tending to 'burp' off and on previously if you didn't have the trigger pulled.
    If it is this, espares do the bit required, reasonably cheaply.
    John :)
    • Thanks Thanks x 1
  3. Sponsored Links
  4. Stevie5tapes
    Stevie5tapes
    13 Jan 2008
    49
    Thanks Received:
    Bradford
    Country:
    Its not leaking water and was running fine for twenty minutes or so then just went funny. I'll get a parts diagram and take it to bits. Thanks for the advice!
  5. Burnerman
    Burnerman
    7 Feb 2008
    23,138
    Thanks Received:
    4,499
    Northumberland
    Country:
    They don't leak water because the leak is internal, and effectively prevents pressurisation.
    As with all these DIY washers, use them for no longer than 10 mins, and then rest them for 10. (Straight from the voice of Karcher UK!)
    John :)
  6. Sponsored Links
  7. Stevie5tapes
    Stevie5tapes
    13 Jan 2008
    49
    Thanks Received:
    Bradford
    Country:
    Right, need to get some torq drivers from work (i will return them!) then have a look at it. It was a cheap one I got from the Karcher outlet (reconditioned) but I dont want to have to buy a new one if possible.
    Thanks again.
    Steve
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
