I am making a kayak cart using the following design:
http://palmettokayakfishing.blogspot.co.uk/2011/04/diy-bulletproof-kayak-cart-build.html
However, I can't find the end caps that I'm supposed to drill a 5/8" hole through and put the treaded rod/axle through that.
I've tried instead to put the PVC end pipe round the past of the wheel but it then turns inside the PVC pipe. Would grease sort that out? I'm worried that it will wear through the plastic after a while:
