I am just starting to rebuild my front porch, weather permitting
and before I start my brickwork, I have a couple of questions.
I have set out the position for the 1st course of engineering brick, in pencil on the foundation and worked on the basis for the front wall being 10No. brick lengths, each 215mm long with 9No. joints, each 10mm wide, to give an overall measurement of 2440mm
Would the correct way to work be either:-
a) Set the two bricks at either end first ie the corners, off my pencil marks and then lay the bricks in between the two or
b) Start at one end by putting in the corner brick and then work along to the opposite corner
Also, when setting the bricks, what is the easiest or most common way to ensure that I maintain both a 10mm width between each of the bricks and a 10mm bed joint on each course.
Thanks in advance for any responses.
