I have a Keston 60 boiler. A few months ago, it started having ignition problems - had the Ram box changed but that made no difference. We then noticed that the pressure was also excessive and that it would increase to 3bars within a few hours (from 1 bar), but then come back down. We changed the expansion vessel and that made no difference either - if anything, it now goes to 3 bars even quicker (and then subsequently drops). It looks like the burner stays continually on, which means the boiler never has time to cool down (before re-firing) hence pressure builds. Further, once I have manually turned it off, it refuses to re-ignite until 2 or 3 hours, presumably for a part to cool down (though I don't know which one).
Can you think of any sensor which needs to be checked or replaced for the pressure problem?
Also, can any one explain the ignition problem immediately after a burn?
Any ideas will be highly appreciated. Thanks
