Kingley drift/swedging tool.
  • Thread starter Thread starter 1JuanKerr
  • Start date Start date
1JuanKerr
Any real Plumbers know where we can buy 15/22mm Kingley drift/swedging tools??
Due to the increasing copper tube prices, can anyone please tell me if they have resorted to using Table Z tube? And what sort of money they are paying for it??
Thanks chaps.
Do you mean tube expanders, or socket-knockers as my lads on Merseyside used to call them?
No MM, it's a swedging tool for type B Kingley compression fittings. Handy for making a tap connector with a compression nut or if you can't find an olive for a type A compression fitting.
You'll have more luck looking for a 'swaging' tool, rather than a 'swedging' tool.
Not often you see a user name being absolutely perfect for the poster :wink:
Ye are showing your age here but they were a good tool. (i called it a swedger too.)
I have one, infact i might have 2, in an old tool box out in the garage. I think the ballbearing has fallen out the 3/4 bit but i'm keeping them as i might have to take it to the antiques roadshow along with my lead dummy, stavers, short rsed drifts and pipe clamps and a load of other forgotten stuff.
I might just dig them all out later and show the boy on Monday as a further part of his ongoing education program :wink:
if it's the thing i remember
its a shouldered mandrel that fits into the pipe end
when you turn it with the handle a ball moves out and pushes a ridge into the pipe like a comp olive
when you reverse the turn the ball retracts so you can remove the tool :wink:
Oi, you been in my tool box again 'tamz'??!!
No it is like a stepped reducer with a thin bar through it. 1st part for 15mm then 22mm. There is a ball bearing inside and when you turn the bar clockwise it pushes the ball bearing out. Keep turning it and it will expand a grove around the pipe. Turn the bar back and the ball bearing retracts and remove the tool.
Simple yet very effective tool.
