- Joined
- 13 Nov 2026
- Messages
- 1
- Reaction score
- 0
- Country
A kitchen backsplash does two jobs at once: it protects the wall behind your hob and sink from water and grease, and it sets the look of the whole kitchen. Choosing the right material matters more than most people expect, so here is a practical rundown. Ceramic and porcelain tile are the most common choice — durable, easy to clean, and available in almost any colour or pattern. Glass tile reflects light and suits small kitchens, but it shows every smudge and needs careful grouting. Natural stone such as marble or granite looks superb, yet it is porous, so it must be sealed and re-sealed over time. Peel-and-stick tiles are a budget-friendly, renter-friendly option for a quick refresh, while stainless steel or metal panels suit a modern kitchen and wipe clean easily. Before you buy, measure the area in square feet and order about ten percent extra for cuts and breakage — running short mid-job is the classic mistake. Check where your power outlets sit, because tiles have to be cut around them, and decide whether the backsplash runs to the underside of the cabinets or all the way to the ceiling. For installation, start with a clean, flat wall, dry-lay a row of tiles to plan the pattern, then fix them with thinset adhesive, grout the joints, and seal stone or unglazed tile once dry. The most common mistakes are skipping the dry layout, using the wrong adhesive for the tile type, and forgetting to seal. If you are planning a full kitchen remodel, Renovation Guide HQ (https://renovationguidehq.com/) has a free kitchen remodel cost calculator (https://renovationguidehq.com/kitchen-remodel-cost-calculator/) and a general renovation cost calculator (https://renovationguidehq.com/renovation-cost-calculator/) to help you budget the whole project before you start. A backsplash is a small job on its own, but done well it lifts the entire kitchen.
