Kitchen Cab lighting
26 Jul 2015
Has anyone got any resources on wiring under kitchen cabinets?
Got some at the moment but will be ripping these out.
I'd like to get them on a switch near the main light switch.
Not quite sure what you mean by resources?
Most decent ones nowadays are led and you could wire the switch to power a socket on each run of cabinets.Above the top units would be sensible so that the psu could be plugged in.
Mine operate on a "wave" switch which senses activity and turns the lights on
Resources = Websites/guides!
Wiring lighting is pretty basic. There is a whole section on lighting in the much underused WIKI
start your research here https://www.diynot.com/wiki/Electrics:Lighting
If you want a switch that is fed from your existing switch, you'll need to find out if there is a neutral in the switch, and be prepared to start chiseleing out your walls etc for additional cabling. As you already have lighting in place, a better solution maybe to install a wireless switch (Google 'wireless switch') to control the under cabinet light remotely.
