Kitchen Cabinet shelf clips
15 Nov 2005
South
Cook Islands
I have some Magnet tall cabs, which are provided with a plastic clip whose peg fits into holes in the cab sides, and the shelf slides between the upper and the lower part of this support.
The cabs are currently free-standing, and a couple of times the shelves have fallen down when objects such as books press against the sides and push them apart. This would be catastrophic if I had china or glass in them, and would still happen on the end unit in a row. I am looking for a shelf support that will unobtrusively fit into the hole in the cab wall, but will also fix with a screw or preferably a peg into the bottom of the shelf. I would prefer pegs as it means the shelves can be lifted out and moved when necessary, but will still provide lateral restraint to the sides.
Does such a thing exist?
You could fit a batten under the shelf, then screw the shelf to the batten
i have some chrome metal pegs that are a bit more supportive you can have for nowt
but non are designed to give support and hold the sides my suggestion is choose a middle shelve and screw in from the sides to hold the sides in
You need at least one fixed shelf around centre position to stabilise the unit.
I like the look of those Hafele supports. I would have to glue them into the cab sides to prevent them pulling out, but that should be OK, and the shelves could still lift off. I hope there is is not a minium order value or a big postage cost
Big-all, thank you for your kind offer. Do yours have a fixing into the shelf, though?
foxhole, yes, I think it's necessary because the cabs are nearly 2m high, so the sides are not as stiff as in ordinary size cabs. I am a bit anxious about screws as I don't want anything showing on the outside surface. The ready-drilled holes look about 5mm dia.
If the weight is enough to spread the sides then no pegs even glued will be strong enough to hold the sides together.
