Kitchen cupboards either side of a cooker
22 Nov 2006
Berkshire
Hi all,
I am installing a new kitchen, what is the distance from either side of the cooker line that an upper cupboard can be installed?
Worst case secanario.... Gas
50mm from either side
min 760 directly above
unless manufacturers instructions specify different.
:shock: ...............foh crap!
just installed base units less than 30mm either side of my 1000mm gas cooker!
Will i go to hell?
(probably.....if it catches fire)
if the wall units are more than 450mm from the worktop they can be in line with the sides of the cooker, unluess it is a high level grill in which case you need 150mm either side of the grill if the unit is lower than the grill
