Can anyone recommend where to get stretcher plates or angle brackets of different sizes that are adjustable both vertically and horizontally at the same time.
Looked at all the diy stores and ebay etc and they all seem to have brackets that have two slots on the same side, meaning you can only adjust them in one plane per bracket. Most kitchen fitters seem to recommend using ones with a slot running on a different axis on each side, so you can adjust in both planes on the same fitting.
I can see why they recommend these, because you end up getting it level in one plane, and then find using the screw hole on the other side sends it off level in another plane.
I also need some really large ones to cover some awkward service gaps! Thanks
