Kitchen mixer tap connections
cb7
7 Jun 2008
London
Hello,
Our new kitchen mixer tap is a monobloc. It came with two braided flexi-hose connections. The small ends screw directly onto the tap base - the large ends look about 15mm but have rubber washers in them. Can I fit these onto a standard 15mm compression fitting, or do I need a special connector?
Thanks in advance, cb7
yes you can but don't over tighten or you'll split the rubber washers.
Excellent!
Many thanks for quick and informative reply.
