Hullo. I am confused about lagging pipes / boxing them in. The main problem is in the kitchen where the water pipes run along the outside walls. The kitchen units did not allow for this but I cut a half circle channel to allow the units to sit against the wall. Good plan or not? Do I insulate (with foam padding) both hot and cold water pipes or box them in or both? Will this prevent condensation from collecting underneath the base units? Also, the cold water mains, right in the corner and pretty inaccessible when units are in place; can I insulate this in the same way? The condensation is so bad here it causes puddles on the floor. The floor is concrete - is there any way water can be coming up through the floor?
Thanks - any help much appreciated.
