I am converting a room into a kitchen. I have to install a ring mains, a (radial) circuit for the oven, and a separate radial circuit for the fridge/freezer. I know this will have to be notified. My questions are about routing the cable for the ring.
1. Can I route some of the cable on the surface of the wall behind the cabinets, rather than buried into the wall?
1a. If I can route cables on the surface of the wall, am I right in thinking that they don't have to be in safe zones? Those apply only to buried cable (and only if less than 50mm deep).
2. Can I have a FCU that's part of the ring mains inside a cabinet, on the inner side of the cabinet, in a surface mounting box, with the cables in mini-trunking going through the back of the cabinet? The FCUs feed single, unfused, inaccessible outlets where built-in appliances connect (or flex connection plates, where the appliance comes with pigtails rather than a 13A plug). There would be three cables to each FCU: two from the ring, one for the load.
2a. If I can't have a FCU that's part of the ring mounted inside a cabinet, what about one that's a spur?
2b. If I can't have a FCU mounted in a cabinet at all, what are other ideas about where to place them so that they are not immediately visible? (I wanted them in plain view, but my wife objected when I told her we would have six of them: cooker hood, gas hob (for ignition), plinth heater (hydronic), dishwasher, built-in microwave oven, built-in fridge-freezer).
Also, can you tell me about the notification process? How do the inspections work, and what happens if they find something that's not satisfactory? Are the inspectors typically helpful, or do they try to discourage DIYers like me?
