Kitchen sink waste
11 Mar 2008
Yorkshire
Hi All.
I'm moving my sink to a centre island that I'm installing next week.
The island is up against the outside wall.
I'll be drilling a hole for 40mm pipe under my dpc , is it best to just Mortar the pipe in after I'll make sure I don't damage the membrane etc.
(I can't run above due to the back door ill be running the pipe under )
I'll be running the 40mm solvent pipe under my floor joists, I'll be putting a standard trap on my sink , is there a solvent to push fit adapter on the market, I'll use push fit pipe out of the trap but then need something to convert.
Push fit will work with solvent pipe.
No it wont, the OD of the pipe is a different size. Only way to join the 2 is using a compression joint.
Curious though as to why your doing so much with solvent weld stuff then want to swap to Push Fit, it'll be more professional to do the lot in solvent weld.
Try plunging pushfit when you get a blockage! :unsure:
I am doing it in solvent, its only at the trap I was asking about.
Which I now have the answer to.
+1,
ABS (solvent weld) pipe will fit the trap just as well.
