Hi, I have two new sinks to plumb the wastes from. Am i best having a P-trap under each one, or running them both into one? If so with what arrangement of the tee?
I have McAlpine wastes (plug holes) already.
I am planning on doing it all in 40mm solvent weld pipe and drilling a new hole in the wall to suit the required pipe level. Am i right in thinking that all traps use compression seals to connect to the waste pipe?
I seem to remember also that the 40mm pipe comes in two sizes for solvent weld and push-fit/compression? this would seem to make it necessary to use only compression fittings.
All advice gratefully received!
thanks
thanks
