I'm fitting a shower tray waste which has a 40mm compression outlet, but would like to continue the waste run in 40mm solvent weld if possible. What type of pipe will connect to a compression fitting at one end and a solvent weld fitting at the other? Thanks.
Solvent weld pipe will fit into compression and can then be used with solvent weld components - standard fitting method for basins, baths, showers sinks etc.
