I am in the process of finishing off the install of a food waste disposer but scratching my head as to how I am going to connect the waste pipes up to the arrangement in the photo below. I currently have a Mcalpine setup on the main bowl and trying to integrate this into the original setup, making use of the old outlet for the smaller sink for the waste disposer.
I am not sure how I will be able to connect up the waste to the arrangement I already have with McAlpine connectors (see first photo).
The waste connector on the disposer fits a 40mm outer diameter mcalpine pipe perfectly as a compression fit. I have a few McAlpine Adapters lying around (one it already on the waste outlet in the pic below) but not helping me connect them up!
Is there a special connector/converter I need so I can join them together?
thanks
thanks
