Kitchen worktops - Cheap alternative's ?
16 Jul 2006
Wales
hi there
does anyone have any suggestions please?
instead of replacing the kitchen worktops (too expensive),
are there any other cheap, effective methods of covering the worktops?
can you buy new plastic to stick on top (does it last?)
I was also thinking about aluminium sheeting, and possibly tiling the worktops, but I'm not sure if this is pratical.
any advice please
ok it is quite inexpensive, looking about 50 quid prob.
you are right, not that expensive. :)
I'll just replace them then, thanks.
Another question, I was thinking about making my own kitchen unit cabinets.
what type of wood is best to use?
mdf ok? and can you paint mdf to hide the wood surface texture, what sort of paint do I need for this smooth slightly shiny finish.
thanks for helping
sorry, think it is acrylic paint I want? like the white chairs from ikea (you know what I am on about?) it is smooth paint with slight shine to it, but it does not look cheap, I guess a good primer will prep this up ok?
if you have to make your own cabinets, I would use laminated chipboard or laminated MDF. It has a hard plastic coating and is easy to keep clean. Ssome cheapo cabinets are coated with white or grained vinyl foil, which is rubbish.
You can get it from DIY sheds.
Needs no painting. After assembly you can run white bathroom sealant into the joints to hide any untidy cuts.
If you cut MDF at home you must use a mask and do it outside as the dust is harmful.
Some DIY sheds will cut it to the size of the pieces you need. this will give a smoother edge that if you cut it at home.
you can use dowelled joints or KD connectors
unless you are quite good at woodwork a home-made one will not be very strong or attractive so look to see if you can buy cabs on offer locally. Rigid-built ones ae generally stronger than if you screw them together, but of course are more difficult to transport.
the material is quite heavy.
If you want to put doors on it buy the doors first and design the cabinet to fit.
If you are making a floor-mounted one you can buy adjustable legs.
p.s. if you are fitting new worktops, take off the old ones and measure them carefully and get the supplier to cut it to size. If the old one is a bit loose/tight then try to get the new one a better fit. Beware, the walls of rooms are rarely perfectly straight and square. Unless you have a medium/large circular saw you will not make a clean cut. the hard plastic laminate will wear out your saw and make it blunt, but a TCT tipped saw can cope e.g. when cutting out for the sink.
p.p.s these are some wall cabs I made to fit ready-made unit doors. they are made of 15m laminated chipvoard 300mm deep. the DIY shed cut then to my dimensions and i used a dowelling jig. I am not very good at woodwork but these are reasonable. Once I had designed the measurements I made several.
Thank you John, excellent advice :)
I'll get some laminated wood then, good idea too about buying the door first :idea: I can work around that!
I'm not a carpenter either, but I should be able to do a good job, hopefully. I have only a bench circular saw, so I can't use that. I do have a good jigsaw? but maybe this isn't good for the job, as you say the blades would blunt quickly.
Instead of using vertical chipboards under worktop, I'll be using those glass bricks, obviously build a frame inside for the doors as well.
thanks again
a jigsaw will not give a clean cut in anything, least of all laminated chipboard or worktop.
It's OK for a sink aperture, since the rim of the sink hides the cut.
ok thanks, I'll do the sink hole myself but them pre-cut first.
do wickes cut them for you? if not, I could always rent/buy a circular saw.
thanks again for helping ;)
