Need to extend the 1m cable from the light up to the standard 3 way connection box so can run cables up wall into ceiling space. Can anyone advise what type of cable I should use? Many thanks
Something small and flexible. The LEDS are only 1watt each. Small speaker cable would do it.
Make sure you get the polarity right or they may not work.
