KVM Switches
11 Jan 2004
Hi guys
I want to set up a PC with a monitor but have the option of using the monitor as a second display for a lappy.
We're not bothered about sharing the mouse/keyboard.
Which KVM switch would you recommend specifically for this?
Thanks.
Anything with a button on it. Be prepared to open it up and remove an annoying piezo. Preferably brutally.
Alternatively, use a monitor with multiple inputs (DVI + VGA is common).
Thanks, Monkeh.
What do I have to remove and why?
I am using an LG W2243S. Having had a good look, there seems to be only one VGA input, unless I've missed something.
If your LG is a 22" screen, then just ensure you DO get the right kvm as some will only do up to a certain resolution, commonly 1280x1024.
I have about 3 at work that only reach this resolution, basically because they are only required to.
Sounds like you have 2 devices that would naturally use 2 very different resolutions, ie. desktop 1920x1080 and laptop 1200x800(?).
This caused me a few issues in the past as the laptop res looked awful on a larger monitor that had a higher native resolution.
As monkeh said, shame you don't have a dual port monitor, sometimes its much easier.
That's the trouble. You buy something not realising in the future your other half will want to buy a laptop and want to use a second monitor.
Personally, I think it's a bit greedy.... :wink:
Thanks jacko too. I'll see what I can find.
