laminate Floor, Electric UFH (underfloor heating), underlay
3 Nov 2011
Hampshire
Just about to put down a conservatory laminate floor over a new chipboard floor which in turn sits on insulation over an old concrete floor. The UFH mat is made up of wires 3mm thick. The mat will cover about 70% of the floor. I am concerned the laminate will be resting over hard spots created by the UFH mat and wonder what is the best underlay to use. Too thin and the mat will create hard spots, too thick and I guess the laminate could deform under point loads (sofa feet for example). Alternatively I could put the heating mat under the chipboard but it wont then give a fast warm floor which is what I wanted. Any advice?
You need to find out the tog rating that is suitable for the UFH mat to work efficiently (in the UFH specs)
Then the flooring should have it's tog rating and you then need to work out what rating you have left for underlay. Look at different types of underlays and see what you can work too on their tog ratings, you may find your limited to what type of underlay you can use as you don't want anything that will over insulate and damage the system.
