I'm about to replace my carpet in the hallway with laminate flooring.
The flooring is currently concrete.
I was planning on cutting the laminate so that there is a hole in front of the front door in which I was going to put something like a coir mat. I was going to build a frame around the inside of the hole and screw this to the floor.
Does this sound about right?
Do I need to put any underlay or something under the mat on top of the concrete floor? Can I use 'no more nails' or equivalent to stick the mat to the floor?
Enough questions!!
Thanks in advance,
Gaz
Enough questions!!
Thanks in advance,
Gaz
