Laminate Flooring, Relaying
15 Jun 2004
Norwich
Had to lift my Laminate floor, found tip on here as to how to get it up.
Managed it without problem.
Unfurtunatly I had to lift it from the end that was originaly laid first.
Now cant lay the last 2 boards as I cant get to tap them, also the last board is fitting under the door architrave.
I have laid it got a couple of gaps, hope it dosnt move.
Any tips.
Heloo there
had to lift and re lay loads of laminate in my wrk i assume u have the groove facing out and the tounge facing in giving u a problem ig u get a stanley knife and run it along the tounge and take off the small lip about 1mm by 2mm then try it again u may find it wont lock in tight if this is the case simply use some wood glue and wedge it against ur wall till it drys
as fot the holes either cut another piece of laminate or u can get sum really descent fillers thoigh try and stick to a flexiable one more like a silicone than a wood filler
