laminate flooring
You can get it but it still warps if you get a constant leak.
You are better of with vinyl.
yes you can. look for stuff with AC5 on it. Most other stuff will be AC 3
laminate flooring is not water resistant. You'd better use other products.
And Aquastep but its expensive at £40 sq mtr. Its totally waterproof though. I posted a topic a few days ago asking if anybody had used Aquastep but there's been no replies.
modern flooring for wet areas uses pvc instead off wood so dosnt suffer from swelling/delamination
i havent used it personaly so cant comment
although at the time off this post plastic flooring wasnt an option :D :D :wink:
