I have a marble effect laminate worktop in which I made a small (2cm x 2cm) burn in with a hot saucepan by the sink. It cracked the laminate and raised (bubbled) it from the chipboard underneath.
I carefully cut the laminate top in a square around the bubble and glued in some new laminate from the strip of the same stuff that you get for covering the bare ends of the work surface. Then filled the edges around it with the colour sealant you can buy to hide joins etc.
This worked fine for a while but water has now got in underneath and the patch is raising and water is getting to the chipboard. I do not want to have to replace the whole work top and I need to do something before the water 'blows' chip board.
I have a small piece of the work surface left and could cut out a 3cm diameter 'plug from this and insert it into a round hole that I can drill through the work surface.
BUT
I am afraid that the same thing will happen again round the edges of the 'plug', water will get in again after time and then the problem will be much bigger!
Please can anyone advise what I can do to repair this before it gets worse?
BUT
