I have a Lamona HJA 8704 and it stops after about 5 seconds of filling water. Then after some delay, 2-3 minutes, the 90minute and Super Rapid Button Lights flash twice, wait and repeat.
With a bit to testing, I have found the inlet triple valve to be faulty.
Part number: 41029153
One of the three valves did not function when 240Volts applied to it.
Conclusion:
Fault Code: the 90minute and Super Rapid Button Lights flash twice, wait and repeat.
Means: Lack on incoming water. So, either no water reaching the machine, or a faulty value.
I have same machine ( Lamona HJA 8704) it stopped while draining with the load of clothing in
Same lights (90 min and Super Rapid) are flashing but eleven times at a time, wait and repeat again.
Can anyone suggest how to rectify?
