LAMONA HJA 8704 WASHER DRYER
the same button tripped again - this is the only tube i can see at the back of the drum - its about 18" long !
back of the drum
under the drum
top of machine
Undo the heater box and see if there's any fluff build up on the fan assy and the heater. Can't see the condenser it must be under the heater box it should be a big container that takes the fluff away , do them checks then as zipper says get a new toc they did change them on a upgrade due to be over sensitive. If it gets top hot ie too much fluff they trip out some trip at 110 degrees some at 170.
one switch still tripping but dryer seems to still work - will change the toc first with the one zipper suggested and see if that fixes it !
thanks guys !
hi zipper - got and installed the replacement as suggested it was a different part number than the old one and fits perfect - washer on it's third test run now and it's drying fine !
thanks for the advice and parts info - v much appreciated ! :lol:
just an update - tripped again - howdens engineer replaced duct and fan - seems the fan wasn't complete in the channel - ok now !
