On the Landing double switch. One switch on the landing light will only switch the bathroom light on and off, ok that is correct !
When you switch the switch off down stairs in the hall, to switch the landing light off that works ok !
Then when you switch the Landing light off upstairs the Downstairs switch doesn't have any effect.
This worked,
Any one got any ideas what is wrong or does this need the same feed
In the back of the switch also was a small red wire taped up that is live shouldnt this be connected also.
Paul
The wiring for the Double Switch is as below.
Bathroom Top Black wire with Red sheath on
Bottom Small Red in one on the left of the switch
Other Bottom Empty
Landing Top Black wire with Red sheath
Bottom Left Black wire with Red sheath
Bottom Right Thin Red wire
Taped up Small Red Wire ( Constant live )
