I have just had a lump fall off my ceiling!!!!!
I have a lath and plaster ceiling which has previously (5 years ago) had a leak in the roof.
There was a bulge in the ceiling and, while changing a light bulb, i prodded it!! (big mistake!!!)
A lump of plaster fell off leaving a hole about 6" by 8". The lath is in good repair behind it adn i have brushed off all the loose plaster from around the edges.
However, what should I fill it with??
Is there somehting special I should use or will a patch of bog-standard Polyfilla do the trick.
The whole ceiling is going to be covered with lining paper and painted afterwards.
