L
lms
Hello everyone, I'm new here, so be carefull with me!
I'm from a mechanical background, not the building trade, but I'm not scared to have a go at most jobs, so is why I'm having a crack at a new patio. I have several questions for you (I have used the search feature and got some answers).
A bit of background first - patio area is to be around 9m square and will stretch the width of the house and up against it. The flags will be 450mm square cast concrete made to look like sandstone type. The existing patio is six 2'x 3' concrete slabs outside the patio doors (standard new house build attire!).
I have already dug out around 4 - 6 inches of soil and luckily that seems to be where the building rubble and clay start. It's very firm. About 1 inch of the foundations is also showing. The existing patio is sitting on a sub base. The slabs surface are 6 inches below the DPC and slope about 1 degree away from the house. They haven't moved in 7 years so all was done correctly.
Question 1 - I have a lot of spare decorative Cotwold chipping gravel 20-30mm. Could I use this for a sub base? I know it would need binding. What would I bind it with..sand?...sand and cement? ratios? It used to compact quite well under foot, so I assume with fines added it should be suitable when compacted with a whacker?
Question 2 - Can I leave the existing sub base where the 6 original flags are? It's very good. Just worried about the joins between this and new base (settlement of the new base)
Question 3 - Would it be better to lay the flags on a bed of sand or a mortar base?
Thanks for your time, any advice appreciated.
lms
lms
