Hi
Sorry if this has all been asked before.
I am laying approx 55sqm of 18mm thick 190mm wide oak engineered flooring. 35sqm in a living room and the remainder in the hallway. The hallway is approx 8m long leading into the living room which is approx 7m long. Will be laying the boards lengthways along that 15m run.
I think I need to have an expansion gap at the threshold of the living room and hallway rather than run it right through, is that correct?
The living room is mostly level apart from near the edges where it dips approx 5mm over 50cm. I need to level that.
The living room concrete floor was laid in 1994 and has a DPM. Do I still need a DPM underlay or should I go with something else like fibreboard?
The hallway is circa 1930 so I need a DPM here. However one half of it is parquet blocks. Am considering laying the boards over the blocks with a non DPM underlay to allow the blocks to breath. Am I crazy?
Thanks a lot
Mike
Thanks a lot
Mike
