Laying central heating pipes in concrete floor?
16 Sep 2007
London
Hello
I'd like to relocate the radiator in my lounge to the other side of the room which has a concrete floor. The is no neat or easy way to reach the other side of the room by running pipes around the walls, so I was wondering if it is viable to cut a channel in the concrete floor and hide the pipes just under the surface? I could then run the pipes from the existing radiator location to the new one.
This is the ground floor of a semi detached house, so would the floor be simple concrete and not reinforced?
Thanks for your advice
Robin
Yes, that's fine to do. Just make sure there aren't pipes in there already, or you'll get wet!
Robin
Most likely to be a sand/cement screed on the concrete - up to 75mm thick;)
if its a floating screed on top of insulation it might crack along the pipe chase.
some screed has chicken wire in it, but it wont have reinforcing mesh
A metal detector or cable and pipe locator might be able to find chicken mesh or pipes if any are buried in the floor.
