Laying Decking on the ground
16 Sep 2007
London
I'd like to lay a decking frame directly onto the ground, since it doesn't need to be elevated.
The area of ground has good drainage and has been dug out to several inches and filled with a weed membrane and shingle.
Could I lay the deck frame directly on top of the shingle, or should I perhaps first put a layer of sand over the shingle?
I'm concerned that whenever we step on the decking we might hear a crunch from the shingle underneath :o although I presume it would bed down fairly quickly?
You need to support the frame with concrete slabs or posts that are concreted into the ground.
Placing a frame directly on shingle is only going to cause you issues in the long term. As you walk on the deck each of the stones will move and your deck will be become uneven and tilt towards the mostwalked on areas.
Build your frame and lay it on sturdy concrete slabs at 1600mm intervals.
Before puttin gthe frame on top you should make sure you get all the slabs level.
Depending on the size of your deck you will then need to somehow anchor it into the ground.
