Laying floor boards on old floor boards
15 Jan 2004
Hi
I want to put down new T&G floor boards in my bathroom and varnish them for a natural finish. The problem is getting the old boards up. The joist positions are outside the room and partition walls are on top of them. I don't really want to clean the origional floor up because it has shrunk quite a lot. Could i lay new boards straight on top of the old boards ? and secret nail them through into the old boards ?
Thanks all
Coggy
just my opinion:
you could, but you then end up with a step (all be it small) into the bathroom, door (if open inwards) wont open, bath panel (if fitted) will have its bottom edge non acessable
you will have to cut carefully around toilet base, hand basin base and also as previously mentioned.
could you not take all existing floor boards out (except under bath) but toilet and hand basin would have to come out, put "noggins" along exising joists and fix new floor ends to these.
lay t & g floor realise that its a pain in the "insert word of your choice here" to get the middle board up to get under the floor for light below and wish you had never done it in the first place.
Thanks for the quick re-ply
Yes noggings is an option. I realise there will be a small step and was thinking of putting a s/wood door strip there and then the landing carpet can be laid up to that.
If i lay it on top the hand basin cut out won't be much of a problem as i am boxing in underneath it and putting a couple of doors on it using cladding, finished to match the floor, so the cut out wont be seen until you open the cupboard doors.
There is no toilet in the bathroom it is in a sperate small loo room
Coggy
I think that the main problem would be if you ever need to get under the floor for access to electrics, water pipes or waste pipes. It is bad enough to get through a single T&G floor in a decent fashion, but I think if there are 2 layers it would be very difficult to get the floor back down nice and level
