    Dismiss Notice
Laying laminate.
Discussion in 'Floors, Stairs and Lofts' started by BARCUD, 24 Nov 2013.
  1. BARCUD
    BARCUD
    18 Sep 2008
    163
    Thanks Received:
    Gwynedd
    Country:
    Hi all, while laying laminate flooring I've realised that one end of the room is nearly 2" wider. I've just put 3 rows down. Is it best just to run the boards parallel with the longest wall or is there something else I should be doing? The final row will run along a wall including a door.
  2. crazydaze
    crazydaze
    30 Oct 2009
    1,023
    Thanks Received:
    148
    Surrey
    Country:
    you lay the first three rows out along the first wall square to the room, NOT the skirting, then scribe along the skirting edge onto the flooring with a pencil.
    This will give you a wonky line down the entire first row following the skkirting edge.
    Lift all the flooring.
    Cut the edge of the laminate on the first row that you have scribed with a jigsaw. Now refit the rows, the expansion gap will be uniform along the skirting and the floor will be straight to the room, continue fitting the floor, you will need to do something similar before fitting the last row into place.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. BARCUD
    BARCUD
    18 Sep 2008
    163
    Thanks Received:
    Gwynedd
    Country:
    many thanks. Tomorrow I'll have another read of your post and give it a go. fingers crossed!
  5. crazydaze
    crazydaze
    30 Oct 2009
    1,023
    Thanks Received:
    148
    Surrey
    Country:
    Remember, your skirtings won't be perfectly straight, so line the flooring up 'by eye' so it's nice and square visually, then fit the floor to the room, because the room won't fit to the floor - if that makes sense?
    • Thanks Thanks x 1
  6. Sponsored Links
  7. BARCUD
    BARCUD
    18 Sep 2008
    163
    Thanks Received:
    Gwynedd
    Country:
    Panic over! all is well with the world and my laminating skills.
    many thanks again.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
