We had a flood downstairs and all the laminate warped so I am going to lay solid wood this time & have a couple of questions.
The floor is concrete, I have had the old floor up for some weeks now and will not lay the new floor until I have confirmed with a damp meter that it is OK.
I have the new floor and solid floor underlay (the one with one side sticky) from B&Q.
1. There is conflicting instructions between the underlay and the floor boxes. Should I glue the joints or not. The underlay directions suggest not, the floor instruction suggest I should.
2. Do I need to use a vapour barrier? There is no indication on either that this is required for solid floor on concrete. The underslay does not seem to have one built in.
3. I have read that the joints should flow away from the windows (or light source, in my case french doors). This is fine for the dining room, but I also intend to flow the floor through an internal door into the hallway, which is at 90deg to the dining room so the joints will flow cross ways rather than length ways in the hall. A way could be to flow length ways in the hall (which has no real light source, no direct windows) but this would mean the dining room joints going cross ways. Would appreciate thoughts please.
Thanks Simon
Thanks Simon
