    Dismiss Notice
Laying out flat roof joists
Discussion in 'Building' started by Robster_1981, 27 May 2020.
  1. Robster_1981
    Robster_1981
    1 Jan 2007
    143
    Thanks Received:
    4
    Manchester
    Country:
    Hi all
    I’m currently self building (or mostly self building) a 3m x 5m single storey rear extension, and the next job looming is the roof.
    I’ve got no drawings, so I’m designing stuff as I go, which has been interesting to say the least!!
    I’ve had a brickie in to build the walls, which are finished, but the block work is higher than the outside skin. It’s a cavity wall with 7N concrete block inner and 73mm brick outer skin. I think this is the reason for the difference in height (about 45mm). When I’ve asked him about it, he said that it will all get covered up when the fascia and soffits go in.
    I’m building the roof myself, and I’m doing a warm roof, and I’m a little concerned that the fascia’s are going to be huge to cover the 200mm joists, 120mm insulation and the extra 45mm from the higher block work.
    the way I see it, I have 3 options...
    Cut 45mm off the top of the blocks.
    Build the outer skin up one course, then bed a wall plate on the blockwork to make it even, or
    Leave it as it is and just have a 50mm deeper fascia to cover it.
    Any opinions.
    Oh, I didn’t really discuss the finer points with the brickie. He just knew that I was having a flat roof
  2. Sponsored Links
  3. noseall
    noseall
    2 Feb 2006
    38,187
    Thanks Received:
    2,452
    Staffordshire
    Country:
    You could always finish the deep joists short of the brick-work, add some less deep cradling (fix timber extenders to the side of the joists) that extends to the outer masonry, then build up the brickwork to the underside of the extenders.
    It will result in taller looking brickwork with a bit of an odd depth of masonry above doors and windows though.
    We did this once - bit of a faff...
    • Thanks Thanks x 1
  4. Robster_1981
    Robster_1981
    1 Jan 2007
    143
    Thanks Received:
    4
    Manchester
    Country:
    That’s some job that! Looks great! Something to think about.
    another thing I’ve noticed on your picture is the weep vents above the opening. He hasn’t put any in on mine. The brickwork is straight onto a catnic style steel beam with no cavity tray. He said we don’t need one?
  5. Notch7
    Notch7
    15 Sep 2017
    17,743
    Thanks Received:
    1,244
    Sussex
    Country:
    its because the brickie couldnt be arrised to cut the blocks, so he has created a problem for you
    cutting the blocks is a non starter as they are Hi 7s.
    you could cut a 45mm slot out of the joists -it wont be enough to weaken the joist bearing and it will reduce the fascia height by that much.
    whatever you do, it looks much nicer if you do a stepped fascia -so the main part where the gutter goes is no more than say 200mm.
    Also It looks nicest if you put a gutter all the way around -having gutter one side only with upstand on the others is ugly
    fitting an ogee style deep gutter disguises the fascia as well -although if your house gutters are a prominent feature you may want to match.
    • Thanks Thanks x 1
  6. Robster_1981
    Robster_1981
    1 Jan 2007
    143
    Thanks Received:
    4
    Manchester
    Country:
    Thanks Notch, that’s what I thought tbh :rolleyes:
    I like the idea of notching the joists and the stepped fascia, think I’ll go with that!
    about the weep vents...are they needed?
  7. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    2,956
    Thanks Received:
    564
    Durham
    Country:
    As a slight diversion, what roof covering are you planning on? If GRP then be wary, there are a fair few threads about GRP decks being very noisy on warm rooves.
    Weep vents and trays should be above all the openings (and set into the wall above where the extension joins the existing house if that wall is cavity as well), can't really blame the brickie, he could have mentioned them to but you're the project manager so your call
    • Thanks Thanks x 1
  8. johnny2007
    johnny2007
    11 Jan 2012
    944
    Thanks Received:
    145
    London
    Country:
    Ask the brickie to come back, take last row of blocks down and cut them to size.
    It's your home, don't bodge it.
    If he wants a day work because this wasn't discussed, well let that be it, at least you won't have sleepless nights thinking about that.
    • Thanks Thanks x 1
  9. ^woody^
    ^woody^
    3 Sep 2006
    28,628
    Thanks Received:
    3,637
    West Mids
    Country:
    I would not be so generous to offer daywork.
    It's wrong, it should not have been done, it should not be paid for - nor to correct it. It should not need to have been discussed and any proper brickie should know how to finish a wall for a flat roof.
    Fascias are deep enough and border on crap-looking when done normally, and no way should they be made deeper.
    • Thanks Thanks x 1
  10. Sponsored Links
  11. Robster_1981
    Robster_1981
    1 Jan 2007
    143
    Thanks Received:
    4
    Manchester
    Country:
    :confused::confused:
    thanks for all the advice!! I think I’m gonna take the top course down and just re-do it myself to save the agro!
    I’m doing an EPDM covering, so I’m going to lap it down over the edges and do a stepped fascia. Not quite sussed out the best way of doing it yet, but I’ll get there...on a side note, pvc fascia is so bloody expensive!!
  12. johnny2007
    johnny2007
    11 Jan 2012
    944
    Thanks Received:
    145
    London
    Country:
    If done properly you do it once and never change it again.
    You just clean it occasionally or do like me, give an extra to the window cleaner and they'll do it for you once a year.
  13. Robster_1981
    Robster_1981
    1 Jan 2007
    143
    Thanks Received:
    4
    Manchester
    Country:
    One thing I didn’t ask. I’ve not had a wall plate put on, so I’m planning on strapping down every third joist (400mm centres). Sound ok?
  14. ^woody^
    ^woody^
    3 Sep 2006
    28,628
    Thanks Received:
    3,637
    West Mids
    Country:
    Sounds normal, except twisted strap every 1500mm would do.
    • Thanks Thanks x 1
  15. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    2,956
    Thanks Received:
    564
    Durham
    Country:
    Have a good search online for your fascia- I needed 400mm for the garage (JJ I beams) a few years ago, best price I found was about £5/metre from this lot https://www.speedyplasticsandresins.co.uk/ . Eurocell wanted something obscene......
    • Thanks Thanks x 1
  16. Robster_1981
    Robster_1981
    1 Jan 2007
    143
    Thanks Received:
    4
    Manchester
    Country:
    Awesome!! Thanks fella’s!! :cool:
Loading...
Share This Page
