Laying Polyflor - advice please
3 Nov 2016
Hi all,
I inherited some Polyflor from a relative who had it leftover, so going to stick in my porch (concrete floor which I've just PVA'd).
I spoke to a friend who's a builder and he said next step was to use self-leveller and then the adhesive floor layers use.
However, I've put a spirit level on it and it's (pretty much) level anyway. Can I get away with no-self-leveller or will I really notice difference?
Also, have read that I may just be able to use PVA as adhesive? Otherwise, have found this stuff: http://www.screwfix.com/p/mapei-ult...ubber-flooring-adhesive-light-cream-5kg/8267h
Final point: porch gets the sun in the morning and it does get pretty hot in there!
Any advice greatly received.
Thanks in advance
Which product is it. Polyflor make lots. If you are going to glue it down it will need a smoothing compound laid 1st.
Does the Porch have a DPM?
If it does not, you'll need a liquid DPM, Moisture tolerant screed like Ardit NA and then fit to that using a Heat Tolerant adhesive, of look at F-Ball Isolator which you can adhere to with certain LT products.
